Frequently Asked Questions (FAQ)
Question 1:
For a vertical vessel, if a positive axial load is entered in the Loads dialog, does it represent a compressive force?
Answer:
A positive axial load entered in the Loads dialog box is interpreted by AutoPIPE Vessel as a downward acting vertical force, similar to a weight load.
Whether this load produces tensile or compressive stress depends on the location being evaluated. In general, the load may create compressive stress at points located:
- Below the load application point, and
- Above the vessel support junction.
Therefore, a positive axial load does not inherently mean compression everywhere in the vessel; the resulting stress condition depends on the load path and the location under consideration.
Question 2:
Why do the calculated values of f1 and f2 appear negative for positive pressure cases and positive for negative pressure cases?
Answer:
The sign convention for f1 and f2 follows the pressure loading condition:
Internal Pressure
- Positive values indicate tensile forces.
- Negative values indicate compressive forces.
External Pressure
- Positive values indicate compressive forces.
- Negative values indicate tensile forces.
When reviewing f1 and f2 results, it is important to interpret the sign based on the applicable pressure condition (internal or external) and the associated stress state.
Bentley AutoPIPE Vessel
Support Solutions and FAQ's
Error Messages
Warning Messages
Calculations
