| Version(s): | ALL |
| Area: | General |
| Date Logged & Current Version |
June 2023 43.01.01.011 |
How to calculate the Test Pressure and allowable stress for hydrotest case?
Test Pressure :
Pt = 1.3 MAWP ( Sa / S )min,
See below code reference,
Test Allowable Stress :
Refer below references for calculation of allowable stress in hydrotest condition,
1. According to ASME Section VIII Div. 2, Clause 4.1.6.2,
Allowable stress = 95 % of yield strength
2. According to ASME Section VIII Div. 1,
Generally allowable stress = 90 % of yield strength.
Note that 90 % yield limit is not given in code but it is common praxis.
If you want to change the allowable stress at hydrotest pressure case please follow below steps,
Step-1: Select user defined safety factors from Vessel Properties<Design Conditions<Design Values<User Defined<Edit
Step-2: Change C4 % value to desired one. You will get required safety factor.
For Heatex, the horizontal test condition must be selected ("vertical" is not considered for this specific type of model).
Horizontal/Vertical orientation does not make sense for Heatex.
