| Version(s): | ALL |
| Area: | General |
| Date Logged & Current Version | June 2023 43.01.01.011 |
Why there are significantly higher values in wind loading in some particular sections of vessels despite the model no platforms / ladders or other equipment?
Those loads appear because AutoPIPE Vessel is considering that there is a platform and ladder supported every 8 meter even though they are not modelled.
To avoid this, please uncheck the option in the Load Case:,
