| Version(s): | ALL |
| Area: | General |
| Date Logged & Current Version | June 2023 41.01.01.011 |
The program do not finish the calculation
This could be happen due to wrong or incomplete modelling of the equipment, Few of the reason could be as follows,
1. Incorrect modelling of heat exchanger type / components
2. Channel head missing in the model
3. Not enough component added with respect to the type of heat exchanger
