| Product: | RAM Concrete | ||
| First Affected Version: | |||
| Found in Version: | 15.03.00.00 | ||
| Released in Version: | 15.06.00.000 | ||
| Area: | Design | ||
| Issue #: | 626269 |
ACI 318-11 7.10.4.3 states that the clear spacing between spirals shall not exceed 3 in. This requirement was not checked by the program. Columns with spiral reinforcing may have been designed with a larger spacing and no design warning was produced. All ACI 318 codes were affected.
Update to version 15.06 or later.
