E. AD 2000-Merkblatter
AD 2000-Merkblatt sections covered
Allowable Compressive Stress (fc) as per AD 2000
Saddle design as per AD S3/2
Nozzle opening reinforcement calculations for External Pressure
Design parameters b & B1 calculated for Integral Flange with Swing Bolt acc to AD 2000
Reinforcement Opening Calculation Under External Pressure in AD 2000
Fatigue calculations not dependent on thickness
Support Solutions and FAQ's
System Messages (ex. Error, Warning, etc..)
Bentley AutoPIPE Vessel
