| Product(s): | RAM Structural System; Ram Concept; RAM Connection; RAM Elements | ||
| Version(s): | All | ||
| Area: | Graphics; User Interface | ||
| Issue#: |
When accessing the RAM Structural System or other RAM programs from a remote desktop connection, through VPN or other virtualization software, one of the following errors is displayed:
"LoadLibrary failed with error 126: The specified module could not be found”
“LoadLibrary failed with error 87: The parameter is incorrect”
First, search for and install updated video drivers from your machine manufacturer's web page.
If the problem persists, try disabling the Integrated Intel HD display adapter and then restart the RDP session.
Can't Select a Member in Plan, Elevation, 3D View
[[RAM SS 3D Viewer FAQ]]
