| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version | Aug 2023 23.00.00.230 |
Model piping arrangement:
There are multiple options to model connected piping to a Vessel / Tank surface, here is one modeling approach.
See WIKI here for other modeling approaches
Step 1. Insert Vessel / Tank | ||
Step 2. Insert conical portion of Vessel / Tank | ||
Step 3. Insert piping arrangement connected to nozzle at Also recommend to insert a User SIF at the Optional: Report Allowable forces and Moments Insert reference points at nozzle connection | ||
Step 4. Note, the legs are attached to the vessel / tank Make this node point the active node. | ||
Step 5. Insert Beam Properties that matches that of the Insert temporary beam from the center of the | ||
Step 6. Insert temporary beam from surface of the Document total length from center of Vessel / | ||
Step 7. Insert vertical beam leg and remove previous | ||
Step 8. Insert remaining vertical legs equally spaced | ||
Step 9. Select all legs and Rotate 45 deg about the | ||
Step 9. Select the top of beam section used for the Leg | ||
Step 10. Done |
Model piping connected the end of a tank / vessel
