| Product(s): | RAM Structural System | ||
| Version(s): | 15.00.00.00 | ||
| Area: | Import/Export |
You have installed RAM Structural System CONNECT Edition v15.00.00.00 but the columns and beams are not exporting when you use File - ISM - Create Repository.
Verify that you have already installed the Structural Synchronizer CONNECT Edition 10.00.00.05. If not, installing it should fix the problem. You can download the CONNECT Edition here:
Bentley Structural Synchronizer
Integrated Structural Modeling Home
