Q. Where to download ATS for a certain version of AutoPIPE?
Answer:
Are you apart of the QA program?
IF no,
Options available are:
a. Use the ITS (see here) or
b. Join as a new QA program member; contact Joanie Mayberry, requesting instructions on how to join the QA program.
If yes,
Thank you for your participation in the QA program. Starting with AutoPIPE version 24.00.2.243 and higher releases, QA users will receive an email notification sent to the designated company contact listed on form 6-1-2 (Contact Personnel for "QA & Reporting" Subscriptions). This email will contain information about the availability of a new QA version of AutoPIPE.
Example:
Bentley AutoPIPE 2024 (v24.00.02.243) can be downloaded from: https://softwaredownloads.bentley.com/en/
The compatible Acceptance Test Set (v24.00.02.019) is available for download: here
A Certificate of Compliance is attached herewith.
If you are unsure of the designated contact person, please reach out to Joanie Mayberry to obtain that information. Additionally, if a specific version is no longer accessible for download or if a DVD has been misplaced, please contact Joanie for available options.
ATS and Batch Processing - AutoPIPE
QA program
Download, Install, Release Note information
