| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | Analysis | ||
| Date Logged & Current Version | Dec. 2014 33.02.02.04 |
While modeling a tank, application displayed message while executing Strength calculations.
Problem Event Name: APPCRASH
Application Name: procal.exe
In this user's case, the reason is simple: it is not a Tank!
The user tried to make a Tank in using a vertical vessel model and moreover in using a pressure vessel code (CODAP), it doesn't make sense.
Only Tank with API 650 can be modeled with APV.
