Applies To | |||
Product(s): | RAM Elements; Retaining Wall Module | ||
Version(s): | 12.01.00.29 | ||
Area: | Analysis | ||
Passive Pressure Sliding Check Retaining Wall
There is no way to prevent the use of passive pressure to resist sliding. There is a box that allows it to be eliminated for overturning, but not one for sliding. Some soil reports say not to use the passive pressure.
Problem ID#: 70540
Workaround: None
