| Version(s): | ALL |
| Area: | Crashed |
| Date Logged & Current Version | Aug 2018 40.07.00.007 |
The following appears when using AutoPIPE Vessel:
forrtl: severe (408): fort: (11): Subscript #3 of the array TABP has value 0 which is less than the lower bound of 1
Why and how to avoid it?
In this example, a model design method was set to Checked Design (Vessel Properties> Design Parameters) therefore all data for load cases must be supplied. After reviewing each load case, found earthquake was missing required data:
After filling in the required data, the program was able to perform a strength calculation without displaying the error message above.
