| Version(s): | All |
| Environment: | N/A |
| Date Logged & Current Version |
June 2023 43.01.01.11 |
Drawing generation crashes even after successfully completion of strength calculations.
The following error appears when AutoPIPE Vessel start generating drawing,
Intel(r) Visual Fortran run-time error
forrtl: severe (408): fort: (11): Subscript #1 of the array COMPONENTIN which is less than the lower bound of 1
OK
Why does this happen and how to avoid?
When Leg Axis to Shell [E] is different than zero (negative or positive), the Drawing generation crashes.
There is a bug in software, error occurs in vertical vessel which is supported on leg and having eccentricity in leg support.
After removing the Leg Axis to Shell [E] value, the program was able to perform a strength calculation & generate the drawing without displaying the error message above.
A bug has been created and development team is working on fixing this bug and will be implemented as soon as possible.
