Q. How Do I Install Bentley AutoPIPE CONNECT 12.06 to 12.08?
Product(s): AutoPIPE
Version(s): CONNECT
Area: Install
  Date Logged
& Current Version
May 2021
12.06.00.48
Problem:
How do I Install Bentley AutoPIPE CONNECT v.12.06 to 12.08.?
Notes:
1. This installation procedure may apply to more than one version, therefore just consider version number as a reference that can vary.
2. There is a possibility that the computer may need to be restarted, therefore highly suggested to save all current work and close all running applications before continuing below.
3. Average time to install
i. if all .Net file are currently NOT installed, approximately 25+ minutes
ii. if all .Net file are currently installed, approximately 10 - 12 minutes
4. This procedure assumes that SES Licensing has been installed and configured, If not please contact the license group to assist you.
5. User currently logged into the computer must have full Administration rights.
6. Suggest program installed by accepting all the default settings
7. Prefer that the application was NOT installed over a network connection; suggest that the EXE file is on the user's system before starting the installation.
8. If a previous version of AutoPIPE was installed on the current computer, suggest to uninstall:
       i.  all previous versions of AutoPIPE
       ii. " PCF to NTL translator
       iii. " ADLPipe to NTL translator
       iv. " Bentley STRAIT
9. ***Important***Remember to always reset your profile if installing over an SES licensed version of the application (ex. v 12.0 and higher).
Installation:
Navigate to the *.EXE file downloaded using the download procedure.
Double click on the *.EXE  file (ex. Setup_AutoPIPEx86_12.06.00.048.exe) to start the installation process.
Note: Be patient while the application is installing as it is checking to verify programs already installed, verifying drive space, etc.. there may be periods when it appears nothing is happening. Give the system time. In the event the installation stops a warning / error will be presented. Just follow the prompts and be patient.
See Movie below, press on box located in lower right corner to enlarge video to full screen mode:
After clicking Finish button, AutoPIPE readme file will be displayed, click here for details of this file.
You are Finished !!!
 AutoPIPE has now been installed:
Failed to install:
If the program will not install based on the instructions above, please log a Bentley Service Request mentioning this page and include a copy of the Error log mentioned above
Install Dependencies:
Install any Dependencies that were also downloaded (typically double click on the EXE files that were downloaded (i.e OpenPLANT Isometric Manager, ProjectWise, etc..).
Detailed installation procedures for these other applications can be found on other WIKI pages or readme files.
Continue:
Before starting AutoPIPE, continue to STEP #3: Set-Up Licensing
Download, Install, and License AutoPIPE CONNECT 12.00.xx.xx and higher
