| Product(s): | STAAD Foundation Advanced | ||
| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | General Foundation | ||
| Subarea: | Pile Cap | ||
I have multiple columns which are supported by a single pile cap. How can I model that in STAAD.Foundation Advanced ?
As of now, a pile cap, created in STAAD.Foundation Advanced using the pile cap job type, can only support one column point. If you have multiple columns which are supported by a single pilecap, you will have to create it as a Mat Foundation job and then model the pile cap as a mat. The piles can then be specified under the mat using the Pile spring option.
