| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Reports |
| Date Logged & Current Version | Dec 2022 12.08.03.015 |
Hope to insert page breaks as the user wants.
Example, output about points from A00 to A05 on the first page, and from A06 to A10 on the second page.
Unfortunately at this time, Dec 2022, AutoPIPE reports are automatically generated with few to no user formatting options.
Workaround:
1. Using Quick Reports
Review AutoPIPE's Tools > Tools > Settings > Printer command.
This provides a way to set the font used for printing, set the number of lines on a page, and open the Print Setup dialog. The font and printer setup buttons display standard Windows dialogs which allows selection of a font, selection any of the printers currently configured to run in Windows, set the page orientation, and to specify the paper size in use.
This command does not affect the Word reports.
2. Using Word reports
Generate word reports, open in Word, and make manual adjustments to the document as needed.
