02e. "Hydrotest" - AutoPIPE Load Case
The Load> Hydrotest command enables the user to define the hydrotest conditions of a piping system. A hydrotest is a common method for testing the integrity of a piping system before it is put into service. In this test, the piping system is filled with pressurized water and checked for leakage, etc. The Hydrotest option permits a simulation of this scenario. Please note that the AutoPIPE Hydrotest option automatically converts all spring hangers into rigid supports to simulate the holding pin which is still in the spring hanger during the hydrotest.
Note: AutoPIPE 10.01.xx and higher, see the following AutoPIPE help section:
Help > Contents> Contents Tab> Bentley AutoPIPE> Supplemental Documentation> on this page scroll down to see a hyperlink for "Hydrotest Tutorial"
Comments, Questions, and Answers
  1. V-stops are not allowing lateral movement during
  2. Non-linear analysis method
  3. Report: Hydrotest load case settings
  4. High results values
  5. AutoPIPE V8i 09.06.01.10 and higher new hydro test method
  6. Allowable K Factor = 0.9
  7. Allowable: user defined
  8. Allowable value calculation
  9. Please select a valid test pressure case for B31.3 test pressure update
  10. Difference results between the Normal Sustain load (ex. Gr+MaxP (1)) and the Hydrotest Sustain load (ex. Gr+MaxP (2))
  11. Apply more than one hydro-test analysis sets
  12. Hydrotest load are not applied on a segment
  13. W88-24: Allowable based on cold yield Sy may be un-conservative
  14. Gravity load case results weigh more than the Hydrotest gravity load case results
  15. Change test pressure and temperature
  16. Axial Force comparison between Sustain an Hydrotest load case
  17. Why an unexpected Sustain Load Case generated during Hydrotest Setup in ISO 14692?
Loads and Load Sets - AutoPIPE
