- CONNECTION Client - AutoPIPE
CONNECTION Client / Bentley License Tool Landing Page
Note:
a. user MUST sign into Connection Client in order to start licensing an application. Otherwise, user will have 7 days grace period from initial installed date or date or last successful sign in date. Otherwise, application will revert to DEMO mode. Only exception would be if license was checked out.
b. ***Important***, Check Bentley Cloud Services Status for known issues.
Typical Information and Instructions:
Ø  What is CONNECTION Client (FAQ)
> Connection Client page here
Ø  Download - Release notes
> Option #1: Software Download
> Option #2: www.Bentley.com Download
Ø  Install
- Installation issues
Ø  Open
Ø  Sign In
Sign In issues:
> CONNECTION Client Fails to Sign In
> Connection Failure, could not connect
> Issue with usage reported detected. Please run Health Check tool or click here to learn more.
> Federated user cannot sign in
Ø  Update Software
- No updates are shown
Ø  Automatic Authentication
users can sign in with their Windows logins instead of maintaining separate Bentley credentials
- Email and Password reset to blank after filing in and pressing Sign In button
> Reset password
(if you see your Profile page you are already signed in, manually sign out and try the link again).
> Reset password
> Check Proxy settings
> Troubleshooting - see section below
> Messages that appear - see section below
Ø  Refresh and Reset Policy
Ø  Health Check
a. Server mode is on - setting should be off. See wiki page on changing the setting
Ø  Scenarios
Troubleshooting:
First step to diagnoses issues with Connection Client, follow these 8 steps:
Step #1: Restart the computer.
+++ Yes, this may sound trivial but please perform this action.
Step #2: Determine if Connection Client software needs to be updated
Compare version in Release Notes here with software version currently installed on your system.
If needed, update Connection Client using instructions below:
i. Uninstall Current version
ii. Use link here to download latest version
iii. Install newly downloaded version
iv. Most importantly, Reboot the computer
> Known issues
Step #3: Try signing into Connection Client after the computer has finished start-up.
Note:
Check that the company IT department has recently changed the security certificate that your systems uses to prove a computer is legitimate and safe to connect to with Connection Client.  Another words, your computer (or network) did not yet recognize or trust this new “root certificate”, so when trying to sign into Connection Client, it blocked the connection for security reasons. From the user’s point of view, this just looked like “I can’t log in.”  Confirm company did or did not push out the new certificate (either through an update, system policy, or IT deployment). Again if new root certificate was not updated the computer will not trust Bentley’s servers. Correctly install the new root certification. After that, Connection Client could securely connect, and login started working normally.
Are you able to sign into Connection Client.
Yes, Continue to Step #4
No, try to signing directly into ims.bentley.com,
Are you able to sign into this site?
Yes - problem with signing in is directly related to Connection Client, continue to step #4 below
No - issue is related to your IMS account information, contact Bentley Licensing Department or file a Support Case for Log in and Web support (select box in the middle top row) mentioning in the description - unable to sign into IMS.
Step #4: Reset the application by locating the application icon in the tool tray, right click the mouse on the application icon, and Exit the Connection Client service, the program will automatically restart in a few moments, and then try to sign in again.
Note: If the easy reset method above does not work:
Open Task Manager> Details Tab> End task the following processes:
and
Restart the application from the Windows Start menu and try signing into Connection Client again
Continue to Step #5 if still unable to sign into Connection Client
Step #5:  Deleted all temporary internet files, cookies, caches (google instructions for your browser application)
After deleting the items above, now try to sign into Connection Client.
Continue to Step #6 if still unable to sign in.
Step #6: Confirm that list of domains here that the CONNECTION Client needs to access in order to sign in and activate your SES applications.
Contact your internal IT to ask that you're allowed to access domains mentioned above.
Step #7: Confirm company network and firewall does not block Connection Client's read / write ability.
Step #8: Contact Bentley ask to speak with Licensing Team about your issue.
Messages that appear:
- Check Updates failed with error Forbidden
- CONNECTION Client recommends to install Navigator CONNECT
- Could not connect Try again
Solution #1
Solution #2
- Failed to install CONNECTION Client with error code 0x8007543. Fatal error during installation
- Installation Failed (0xFFFFFFFF)
- Microsoft Edge can't read and write to its data directory
- Must be installed on your machine prior to installing CONNECTION Client
- Page Expired Error
- Port failure
- This account is not associated with an organization
- Script Error
- Script Error: Error in DB Script at line ...
Diagnostics:
> Collect:
> Configuring Error Logging Settings (Client Logging)
> Performing a Fiddler trace
> Capturing A Browser Based Network Trace (.HAR File)
Technical Support
Ø
