| Product(s): | Plantflow | ||
| Version(s): | 06.02.xx.xx and higher | ||
| Area: | Download, Install, License | ||
Important:
Bentley PlantFLOW is compatible with:
Windows XP, Windows Vista, Windows Vista x64, Windows XP x64, Windows 7, Windows 7 x64.
This does not mean that the software cannot be run on another operating systems not specified in the readme file, but that it has not been tested/certified by the CAE development team to be installed on another OS. The user can try to install the application on any OS. However, Bentley cannot be held liable for results or provide technical support for installation on untested systems. One may consider installing the application on a Virtual machine running a supported OS.
1. Download PlantFLOW
Since PlantFLOW has been deprecated, it is no longer available for download from Bentley's Software Download site:
Bentley has implemented a new strict internal process for handling requests related to obsolete software. This procedure does not ensure that the requested application will be accessible to the individual making the request. Once a case has been logged and the justification for requiring the outdated software has been submitted, the internal review may take one to two weeks to finalize. Upon completion of this process, individuals will be notified of Bentley's determination regarding the provision of a download link.
2. Install PlantFLOW
This new version of PlantFLOW is able to run on 32 bit and 64 bit versions of Windows XP, VISTA, Win 7,
Note: Bentley cannot be held responsible for results from an installation of this software on an Operating System that is not specified in the application's read-me file. Installing and all output results from Bentley PlantFLOW on these other OS is at your own risk.
Some preliminary tests have shown that the application will install and appears to be functional on Win 8 & higher. These OS have not been fully tested and using the application on these versions of Windows is subject to the disclaimer above.
3. Download Bentley IEG
Use the same procedure above to download Bentley IEG 02.00.20.01 - download here.
4. Install Bentley IEG
This is a separate install and is required
IEG must be installed by user with Admin privileges and cannot be pushed over a network connection. Please confirm you are logged on as an admin user, do not assume
5. Set-up License
PlantFLOW is no longer eligible for subscription renewal or placement on a contract that supports pooled licensing because it has been deprecated. Only a Cancelation Node lock license that is tied to a specific machine by its name can be used to license the product. If you need a Cancelation Node Lock License, please get in touch with your Bentley Salesperson or Bentley Contracts / Renewal department. For the duration of the quarter, this kind of license will only work on one computer.
See WIKI here for managing a node lock license.
Select Server and License Management Tool instructions:
6. Start PlantFLOW software
Application indicates Plus license in use Application is in DEMO mode
