| Product(s): | STAAD.Pro, STAAD Foundation Advanced, STAAD.offshore, RAM Structural System, RAM Elements, RAM Connection, RAM Concept | ||
| Version(s): | N/A | ||
| Environment: | Windows 10 32-bit, Windows 10 64-bit | ||
| Area: | Installation | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group |
Windows 10 was released in July, 2015. All of our current versions of the structural products are compatible in this environment. Windows 11 is too new to definitively verify compatibility.
The search results on Bentley's Software Downloads page display the supported operating systems for each program. You will get this information once you click on the product itself. Consequently, use of the programs on an unsupported operating system is at your own risk.
Please note that Microsoft is supporting backward compatibility with Windows 10 release. So applications which worked fine on Windows 8, should work smoothly on Windows 10.
Does my structural program work under Windows 8?
[[SELECTsupport TechNotes and FAQs]]
