Pressure Vessels
Modeling Techniques:
Standard raised face ring type joint flange
Specify circular weld
2 rings supports
Flat head welded to wall per UW-13-2(d)
Connecting head directly to flange
Weight of packing to the "lifting" load case
Longitudinal weld orientation
Different temperature zones for a vessel
Horizontal Vessel
Custom saddles
Saddles with a stiffener ring
Multiple saddle in horizontal pressure vessel
Platform to a horizontal vessel
Horizontal Vessel with jack 2/3 the distance around the outside
Insert a Boot
Vertical Vessel
Skirt to a pressure vessel
Cone shape skirt
Skirt stiffener
More than 4 vents in the skirt
A structural shape C for skirt attachments as per EN 13445-3 16.12.3.4 (Figure 16.12-3) and AD2000 S3/1
Goose neck nozzle out the bottom of a vertical vessel
Reinforcing pad placed on both shell locations of a vertical vessel
A boot to a vertical vessel
Vertical vessel for transportation in horizontal position
Lifting Vertical Vessel
Report issues:
Why are the weld class represented wrongfully in the output report
Flange rating in program does not match that in the report
Why are there no trunnions characteristics for our vessel in 's output report
Report option "Report determining case only" in the submenu "Report " appears to not be working correctly in
There is an empty page only instead of report after a calculation in output report, why
Why is Bolting Required area = 0 in report
Calculation issues:
Why are Shell and head wall thickness the same
What controls rounding-up the wall thickness
For the combined loading calculation, how is the general stress intensity calculated
What methods are used to calculate the K factor from ASME VIII Div 1
Can Auto Pipe Vessel design the guide support or calculate the reaction on the guide support and corresponding stress on the shell of the tall column
Saddles - Calculation of the horizontal longitudinal reactions (RaHL) When do the sliding saddles start to move
If dc = D2 was applicable to calculate λc only, can this relationship also be apply to equation 49 of GOST R 52857.3 n
Calculate CODAP Isolated opening, Shell stress verification, Nozzle values l , S , and S
What reference was used for Lugs
Miscellaneous issues:
In the annex you will find a file for a vessel according to ASME VIII/2 under internal and external pressure. In the design report it is stated that the opening N03.1 is not adequately reinforced for external pressure.
Why does the Packing Weight summary have a different count than shown in the model view for
When we compute a heat exchanger submitted to wind and earthquake and we select "report determining case only", APV print lifted and erected cases whereas when we print all cases, the determining case is operating.
Consequence of the input of the elevation in the dialog of the bracket or ring
get the nozzle orientation in a view not in a table
What would be the best recommended saddle position for a horizontal vessel in
How can one change the deflection and rotation limits on columns (top and trays) especially for optimization of column design in an Model
How can we change reference point in AutoPipe vessel while designing pressure vessel
How AutoPipe vessel takes care of "After forming thickness" for different kind of pressure vessel "Heads"
In a vertical vessel model with a skirt, the bottom ellipsoidal head needs to be changed to a conical head, but is not graphically drawn correctly in , how to fix it
What is the critical value of half angle at skirt apex considered by the software for GOST code
What is the required thickness for the longitudinal stresses at the circumferential weld (ASME VIII UG-27(c)(2))
Do the horizontal seismic actions in come from the full weight in case (+), and in case (-) come from a reduced weight (reduced = 60% of weight)
What is the meaning of Design Conditions> Characteristics> Category Nominal Stress
Support Solutions and FAQ's
System Messages (ex. Error, Warning, etc..)
Bentley AutoPIPE Vessel
