| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT; | ||
| Area: | Stress Isometric | ||
| Date Logged & Current Version | Aug 2023 23.00.00.230 |
How to add annotation text on an AutoPIPE Stress Isometric using OPIM?
See Video below for exact procedure
Note: select from the bottom right corner of the video to enlarge to full screen mode.
Limitation:
As of Aug 2023, AutoPIPE's Node Annotations (Select > Node Annotations > Node Annotations) are not able to be printed on a Stress Isometric. Kindly follow the instructions here to post / search for an IDEA related to this limitation. The more votes for a feature, the faster it may be incorporated into a future version of AutoPIPE.
Customize AutoPIPE Stress Isometric drawings
