| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | Postprocessing | ||
| Subarea: | |||
How to view the generated moving loads ?
After defining the moving loads, first ensure that the model is analyzed.
One can subsequently follow the process as explained in the screenshot below to view the loads.
As you go on changing the active load case, you will be able to see the wheel load moving along the structure.
Make sure that the View Loading Diagram option is turned on to be able to see the generated moving loads.
STAD.Pro CONNECT Edition
STAAD.Pro v8i
