Batch Processing, ITS, and ATS using AutoPIPE
1. Batch Processing
2. ITS  (Installation Test Set)  -  all users
3. ATS  (AcceptanceTest Set)  -  only AutoPIPE QA&R users, see here
a. Install, License, and Run instructions
b. Release notes
c. FAQ
4. Manually test if the program is functioning properly
QA program
