| Version(s): | All | ||
| Area: | Design | ||
| Subarea: | American Steel Design | ||
How does one define the yield strength of steel or how does one change the value of the yield strength?
FYLD is one of the items specified as parameters for steel design. The STAAD Technical Reference manual and International Design Codes manual contain information on specifying parameters for steel design.
There are example problems in the STAAD Example manual demonstrating how parameters are specified for design. The example below shows some typical post-analysis commands.
PERFORM ANALYSIS PRINT STATICS CHECK
PRINT MEMBER FORCES LIST 5 7
PRINT ELEMENT STRESSES LIST 10 TO 16
UNIT KIP INCH
PARAMETERS
CODE AISC
UNT 1.0 ALL
UNB 20.0 ALL
LY 60 MEMBER 36 40
LZ 60 MEMBER 36 40
FYLD 46.0 MEMBER 47 50
CHECK CODE ALL
FINISH
The same can be done using the graphic user interface as well as shown next
