Graphics  - AutoPIPE
Comments, Questions, and Answers on graphic issues in AutoPIPE:
- See thru AutoPIPE to Desktop or blank screen
- Test your graphics card
- Graphics take a very long time to refresh, slow, sluggish
- Color Plot related issues
- Code stress color map does not blend (dither) from one stress color to another
- Stress color plot shows beams as dark black
- Points disappear when viewing Imposed displacement & valve / flange
- 2 flanges are shown as a single flange
- Select 2nd support at same node point
- Display a displacement magnitude on plot output
- North Arrow in model
- Model Screen graphics appear as a series of dots in Model View
- Input grids indicate items in model, but screen is blank
- Change the scale size of the components
- Anchor graphic partially rotated
- Dialogs do not appear correctly when opened
- Components in Single-Line, Wire Frame, and Solid Model view
- Dialog fonts appear smaller or blurry
- Single line mode, components do not appear to be connected
- Dialog text not aligned correctly
- Tee arrows do not appear
- Hot / Quick keys no longer function
- Which direction is Local X, Y, or Z axes direction
- Force AutoPIPE to use a specific graphics card
- Nvidia graphic cards settings
- Distorted graphics on Dell Alienware computers
- Text  missing from the top of the application screen
- Display ribbons on the screen?
- Most words (except for ProjectWise, OPIM, and Model Explorer) on toolbar & grids are illegible
- All words are missing from ribbon graphics
- When using multiple monitors, dialogs do not appear?
Graphics
