| Product: | RAM Structural System |
| Version: | All |
| Environment: | All |
| Area: | Installation |
Before doing these steps, please make copies of any custom tables that have been added to the program. The default location for tables is:
Ensure that none of your models are saved within the RAM Structural System folder.
Finally, if you have made modifications to your user defaults, please make a copy of your RamIS.ini file. The RAMIS.ini file is located here:
The defaults can be copied into the new configuration file later on, if needed.
Go to the Control Panel. Select Programs and Features. Uninstall RAM Structural System.
For a clean install, it is also recommended that you remove the following folders (if they exist):
Once this is done, reinstall the latest version of RAM Structural System.
After installation, copy any custom tables to the Tables folder. The default location is noted above.
To restore the user defaults to the new RAMIS.ini file
