As a new user one should take the time to thoroughly go through each hyperlink and sub-links to start their journey of using AutoPIPE
(note: changes on the following dialogs may have profound impact on your results)
Note: What Features and Piping codes are available in AutoPIPE Standard, Plus, or Nuclear?
