Consideration of development length of column reinforcement in pile cap depth calculation
 Product(s):STAAD Advanced Concrete Design
 Version(s):All
 Environment: N/A
 Area: Concrete Design
 Subarea: Pilecap Design
 Original Author:Abhisek Mandal
Bentley Technical Support Group
Kindly clarify whether Development Length in Compression (Ld) is considered, while arriving the depth of Foundation for a Pile Cap.
For footing and pile-cap RCDC does not considered the “Ld” of the column reinforcement for minimum depth. Column design is an independent activity thus information of column reinforcement is not available for pile-cap design. User can provide minimum pile-cap depth available in general settings as per Ld requirement. Also if required each pile-cap can be redesigned with required minimum depth.
