Applies To | |||
Product(s): | STAAD Advanced Concrete Design | ||
Version(s): | All | ||
Environment: | N/A | ||
Area: | Concrete Design | ||
Subarea: | Pilecap Design | ||
Original Author: | Abhisek Mandal Bentley Technical Support Group | ||
Can we design pile-cap in RCDC if there is tensile force in column?
No. Presently if there is tension in column, RCDC shows the failure of pile-cap design due to tensile force. We would recommend user to design the pile-cap with Advance foundation design software if there is tension in column.
