Can RCDC design Curved beams? Will it convert the curved beam composed of many parts to a single phy
Product(s):STAAD Advanced Concrete Design
Version(s):Connect Edition
Environment:
Area:Concrete Design
Subarea:Beam design
Original Author:
SANJIB DAS
Bentley Technical Support Group
Can RCDC design Curved beams? Will it convert the curved beam composed of many parts to a single physical beam?
Yes. If curved beam is modelled in sufficient small parts then RCDC identifies it as single beam as per the geometry and support conditions. The beam is designed for Bending, shear and torsion as per regular beam.
