02. Featured and Bugs Logged for AutoPIPE
Problem:
What enhancement / defects request have already been logged for AutoPIPE?
Note:
If an feature or bug has not been added to the program,
In addition, AutoPIPE's development priorities are based on strict rules: number of user requests, merit, importance, available resources, a clear scope of the IDEA requirements, impact on other part of the program, time required to implement, ROI, existing backlog, etc...
The most important step, letting us know what you need.
Remember to review the Bentley AutoPIPE Release Notes and the following AutoPIPE help section:
Help > Contents> Contents Tab> Getting Started > Revision History (contains a list of features added in different versions of AutoPIPE, starting with v6.20.09)
Otherwise, see the following subcategories for logged Enhancements and Defects:
Piping Code
Static
Analysis
Pipe and Piping Components
Combinations
Dynamic
Analysis
Support
Reporting
Wind
Grids
Stress
Isometric
Wave
Library
Export
Soil Load
Settings
Import
Flange
Analysis
Toolbars
and Menu
"Edit"
commands
Rotating
Equipment
Operating System Software
"View"
commands
TTA
Analysis
Graphic
Technology
Preview
X-tra Data
Beam
Hydrotest
DATA API
Critical and High issues
Known issues
