| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | Concrete Design | ||
| Subarea: | Beam design | ||
| Original Author: |
SANJIB DAS Bentley Technical Support Group | ||
Does RCDC allow to provide only 2 bars for top reinforcement?
The Number of Bars suggested by RCDC are as per beam width and maximum spacing criteria given in codes. User can change the numbers of bars prior to design subjected to spacing criteria given in code. For zero bending moment zone RCDC can provide minimum two bars with minimum bar diameter. For more information refer Topic “Preferred Bar Spacing” for beam from help Content.
