Applies To | |||
Product(s): | STAAD Advanced Concrete Design | ||
Version(s): | Connect Edition | ||
Environment: | |||
Area: | Concrete Design | ||
Subarea: | Beam design | ||
Original Author: |
SANJIB DAS Bentley Technical Support Group | ||
Why specifically only 13 stations (for beams) can be imported from E-tabs to RCDC?
13 stations divides the element in to twelve parts. As per standard practice of all codes, curtailments of reinforcement lies at L/4, L/6 and L/3 of span where L is the span of the element. Dividing the element in to 13 station satisfies all the requirements of curtailments. Curtailment of reinforcement helps in beam detailing thus it is mandatory to provide 13 stations to all beams in the analysis. STAAD.Pro automatically provides the results at 13 stations. E-tabs can provide results at any stations as per user requirements Thus in E-tabs user has to assign output stations as 13 before exporting the results. For more information refer topic “Technical Discussion” of beam and Column from help Content.
