| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Export |
| Date Logged & Current Version | April. 2018 11.03.00.08 |
Is the integration between AutoPIPE and STAAD.PRO software version dependent?
Yes, it is version dependent to a degree. Best to have the latest version of both application installed before attempting to transfer data between these applications.
At a minimum, one must have installed AutoPIPE V8i 09.03.xx.xx and higher, in addition, must have installed STAAD 2007 and higher as these are the version where the PIPELINK command was first introduced.
Export Model to STAAD Using PipeLink (*.pipelink)
