What is the purpose of mirror & straight option in group/ungroup tab?
Product(s):STAAD Advanced Concrete Design
Version(s):Connect Edition
Environment:
Area:Concrete Design
Subarea:Beam design
Original Author:
SANJIB DAS
Bentley Technical Support Group
Mirror grouping option can be used if beams are mirror in arrangement with same geometrical properties. So beam on one side can be mirror in detailing of the beam on other side. Similarly if beams are identical in plan i.e. beam geometry is similar at a given level and repetitive then these beams can be grouped. For more information refer Topic “In Plan Grouping” for beam from help Content.
