Applies To | |||
Product(s): | STAAD Advanced Concrete Design | ||
Version(s): | Connect Edition | ||
Environment: | |||
Area: | Concrete Design | ||
Subarea: | Slab Design | ||
Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
There is a form in RCDC (IS 456) slab design to input the permissible limit of l/d ratio for two-way slabs. (With defaults as 28 for SS and 32 for continuous.). However, these values are not valid if the loading class in more than 3 kPa and spans up to 3.5 m. Please clarify.
RCDC is a design software. the recommended values of L/D are available in design settings. i.e. for Two way simply supported slab it is 35 x 0.8 = 28 and for continuous slab it is 40 x 0.8 = 32. refer below snap from IS code.
Please note that option of changing the L/D factors are available in software as per user requirements. we understand that the above ratio available in code has certain limitation of span and loadings. Thus L/D ratio are available to modify by user. User can take the decision on the same and proceed with the design. it is always a user choice to select the L/D ratio which suits the design.
