| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Error |
| Date Logged & Current Version | Nov 2019 12.02.00.14 |
The following message appears in AutoPIPE:
Error
E90-43: Structural Synchronizer not installed on the system.
OK
Why and how to Avoid it?
As mentioned in the message, Structural Synchronizer has not bean installed. Structural Synchronizer is a separate program and needs to be downloaded and installed outside of AutoPIPE's installation. Use Bentley's software download to download the application and install. A machine reboot is needed after this install, best to close all programs and files before starting the Structural Synchronizer installation.
1. Only install the application versions mentioned in AutoPIPE's readme file or that which is apart of the install process. Recommend to not update any application version without explicit instructions from TSG.
Example:
AutoPIPE 23.00.00.230 installs iTwins Analytical Synchronizer Connect Edition v. 12.2.1.10, Do not upgrade to version 23.01.01.56 as it has not been tested / verified to work with this version of AutoPIPE.
