Validation Document for various Elements as per AS 3600:2018,
Beam Crackwidth for Beam
AS-Code_B6_Beam_Crackwidth-check_RCDC Output
Beam design for Flexural, Shear and Torsion (Singly Reinforced)
AS-Code_B21_Beam_flexural, shear and torsion_RCDC Output
Beam Sway Shear Calculation
One Way Slab design (End Span)
One way slab design_End Span_RCDC Output
Two Way Slab Design (Interior Span)
Two way slab design_Interior slab_RCDC Output
Pad Footing Design :
AS3600 - 2018_Design of Pad Footing_RCDC Output
Step Footing Design:
AS3600 - 2018_Design of Step Footing_RCDC Output
Shear Wall Design with BE:
AS3600 - 2018_Design of Shear Wall_RCDC Output
Column_Flexural Check_Non-Ductile_Braced
AS-Code_C13_Column design_Braced_RCDC Output
Column_Flexural Check_Non-Ductile_Un-Braced
AS-Code_C13_Column design_UnBraced_RCDC Output
Column_Shear + Torsion Design
AS-Code_C1_Column design_Shear+Torsion_RCDC Output
