| Product(s): | RAM Structural System | ||
| Version(s): | All | ||
| Area: | RAM Steel | ||
| Subarea: | Connection Check; Reports; Tables | ||
The .con file must be a plain text (ASCII) file in the proper format and located in the program tables directory to be available within the program. The location of the tables folder can be confirmed in the ramis.ini file which is always located here, C:\ProgramData\Bentley\Engineering\RAM Structural System\RamIS.ini. For information on the .con file format, please refer to the RamManager.pdf program manual. If the .con file is not available, try the following steps:
