05. How is the ground elevation determined for a Wind load case in an AutoPIPE model?
Product(s):AutoPIPE,
Version(s):ALL
Environment: N/A
Area: Load
Problem:
How to determine ground elevation in AutoPIPE?
AutoPIPE allows the user to create a piping system anywhere within the coordinate system constraints, BUT, how does the program know where the Ground level is unless you tell it!
Ground level could be anywhere on the vertical axis: ex. -4000 mm, -125 ft, 0 ft, +30 ft, +86645mm, anywhere, etc….
Just identify vertical level where ground level exists, and anything below that vertical level is considered underground. Anything underground will have no wind applied.
Notes:
Example:
Given the following piping system, What value should be entered for "Ground elevation" on the Wind dialog?
Do you agree that 10 feet is correct answer? Yes or No...
If you had answered YES, you are WRONG.
If you had answered "No, need more information", you are CORRECT.
The missing information, what is the Vertical elevation of the elbow at the top of the vertical pipe?
From the Point tab of the input grids, vertical axis = Y-axis, one can see that the Vertical coordinate at the elbow A210 = -225.460
Therefore the Ground elevation = -225.460 - 10 = -235.460 ft.
Correct !!!
Again, baring any Wind Segment settings, any piping above this elevation could have wind applied, but all piping below this elevation would not have any wind applied regardless of Wind / Segment settings.
Modeling "Wind" - Load Case
