| Version(s): | All | ||
| Area: | Error Message | ||
The following is displayed when opening a model in AutoPIPE:
Error
E15-34: Selected material library does not match the verified
standard material installed with this version of the program.
Please select a standard material library installed with this
version of the program or rename your material library to a
non-standard library name and try again.
Please refer to program help for more information.
OK
How to fix this issue?
The problem is the material library that has been selected on the General Model options dialog does appears to be a default material library. We guarantee the data in our shipped libraries is certified. To prevent making modifications to this certified data or reusing a default library name, the program will display the above message.
Option #1: Choose a different default Material library that was installed with the program and has not been modified
Option #2: Choose a valid User created material library from the drop down listing.
or
Option #3: Close AutoPIPE, reload all default material libraries by following Reset Profile instructions here, restart the application and try again.
Note: Prefer to always share / archive models using AutoPIPE APC files. See AutoPIPE help for APC files details. Using these files would help avoid this error message.
