Applies To | |||
Product(s): | STAAD Advanced Concrete Design | ||
Version(s): | Connect Edition | ||
Environment: | |||
Area: | Concrete Design | ||
Subarea: | Footing Design | ||
Original Author: | Suvadeep Acharjee, Bentley Technical Support Group | ||
How is the volume of trapezoidal footing calculated in RCDC?
RCDC calculates the weight of trapezoidal footing as per following formulations, Self-wt. of footing Volume of footing = ((L*B*D) + ((((L*B) + (Lt*Bt))/2)*(D-d))/1000^3 Where, L= Length of footing B= Width of footing D= Depth of footing Lt= Length of footing top Bt= Width of footing top d= depth of sloping area.
