| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | All | ||
| Area: | Concrete Design | ||
| Subarea: | Column & Shear Wall | ||
| Original Author: | Shreyanka Bhattacharjee Bentley Technical Support Group | ||
Lateral ties diameter, spacing & no. of columns main bars are correlated by formula given in IS: 13920 for rectangular and circular column. Can any single parameter be provided to calculate remaining two parameters in RCDC, once the initial design is complete?
Yes. RCDC can design any shape of column like L, T, I, E, Capsule and polygons up to 12 edges. It also has an option to create user defined sections. For more information refer Topic “Irregular Shaped Column” for column from help Content.
