03. Exported related issues in AutoPIPE
- What file formats can AutoPIPE Import/Export?
Comments, Questions, and Answers
a. Export AutoPIPE Batch (NTL)
b. Interface between Projectwise and AutoPIPE
c. AutoPLANT - Geometry/Results (PXF)
d. AutoCAD (DXF)
e. Caesar II neutral (cii)
f. PDMS Compatible XML (XML)
g. Isogen (PCF)
Note:
1. FYI It is a known issue that the bends from AutoPIPE do not show up in 2019 Plant3d. AutoDesk fixed it in release 2021. The bends show up in Plant2d 2021 with the latest patches installed
2. AutoDESK technical support acknowledged known issues with importing AutoPIPE's PCF file into their software. Contact AutoDESK technical support for details and date of resolution.
h. JSpace Model (ISM)
i. DGN Model (DGN)
j. Imodel (imodel)
->Axis orientation when exporting an I-mode
->Do I have to use I-model when exporting a DGN File from AutoPIPE for clash detection
k. LiCAD (Apxt)
l. Input Database (MDB)
m. Results Database (MDB)
n. SACS SQLite Database (DB) - Technology Preview
o. SQLite Database (DB)
p. Nozzle Loads to AutoPIPE Nozzle (PXF)
q. Nozzle Loads to AutoPIPE Vessel (XML)
s. Model to STADD
Model to STAAD Using PipeLink (Pipelink)
using SQLite Pipelink (Pipelink)
using Integrated Structural Modeling (ISM)
t. MS Excel (XLSX or XLS)
u. AutoPIPE Archive (APC)
v. Stress Iso
i DGN
ii DWG
iii DXF
iv 2D DGN
v PDF
w. Export to ISM (Create / Update Repository)
Imported issues
Import/Export file formats
