| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | All | ||
| Area: | Concrete Design | ||
| Subarea: | Column & Shear Wall | ||
| Original Author: | Shreyanka Bhattacharjee Bentley Technical Support Group | ||
In which cases we should not consider perform slenderness check - When to and when not to consider slenderness?
Slenderness check is an option given in RCDC. If the structure is analyzed with the Non-linear load cases (P-Delta) it is not recommended to consider this check. If the structure is analyzed with linear load cases, it is recommended to consider this check. If this check is selected, slenderness check will be performed, and additional slenderness moments will be calculated if column is slender. If this check is not selected, slenderness check will not be performed.
