Applies To | |||
Product(s): | STAAD Advanced Concrete Design | ||
Version(s): | Connect Edition | ||
Environment: | |||
Area: | Concrete Design | ||
Subarea: | Beam design | ||
Original Author: |
SANJIB DAS Bentley Technical Support Group | ||
Why default 0.2% is provided for nominal steel in RCDC? Does it have any reference?
RCDC provides the nominal steel where bending moment is ZERO. Default value provided in RCDC for nominal steel is 0.2 %. This is an approximate Value and we have kept the value close to minimum steel in beam. The above value is editable and can be put as per user requirements. For zone with no Bending Moment, RCDC uses nominal steel and for detailing, it would adopt 2 bars with minimum diameter possible.
