| Version(s): | ALL |
| Area: | Crashed |
| Date Logged & Current Version | October 2023 44.00.00.111 |
The following error appears when using AutoPIPE Vessel:
forrtl servere (408): fort: (10) Subscript #1 of the array VERTEX has value 5 which is greater than the upper bound of 4.
As of October 2023, AutoPIPE Vessel v44.00.00.111 has two known bug for the heat exchanger module as follows,
1. If user changes the default 00 position from Right to any other direction then bundle layout doesn't take the correct orientation of the components.
We suggest to change the default 00 position to Right and change the orientations of all the nozzles and attachments to desired locations.
2. AutoPIPE Vessel shows error if user does not check the Connect with side plates option in Impingement baffle from Tube Bundle Properties.
Check the box and correct the orientation of impingement baffle. This will solve the issue and you can complete the analysis without error.
Both these known bugs are InProgress and it will be available for user in future release.
3. Go through the video attached here for clear understanding of the procedure,
