Open Access queries
 Product(s):STAAD.foundation
 Version(s):05.03.00.00 and earlier
 Environment: N/A
 Area: Licensing - Technical
I recently signed Open Access via SELECT, I'm using STAAD.Pro V8i SS5 (20.07.10.41) or later, I'm unable to use STAAD.foundation within STAAD.Pro. Also, I cannot use STAAD.foundation standalone version 5.3.
Please note that STAAD.foundation has been shelved for few years now. Open Access does not grant a license for this.
Install STAAD.Pro V8i SS5 (20.07.10.41), and STAAD Foundation Advanced V8i version (08.00.00.00) . You will get access to standalone version of STAAD Foundation Advanced and you can also run it from within STAAD.Pro.
In case, your company is yet to certify STAAD.Pro V8i SS5 series, you can install STAAD.Pro V8i SS4 (20.07.09.31) and STAAD Foundation V8i Advanced version (07.00.00.52) or version (06.02.00.11).
Please note that if your company does not own STAAD Foundation Advanced license, you will receive invoice on usage (after the trial period is over).
To get more information about STAAD Foundation Advanced, refer to the link below.
http://communities.bentley.com/other/old_site_member_blogs/bentley_employees/b/stfoundations_blog/archive/2011/09/28/staad-foundation-advanced-has-been-recently-released.aspx
[[STAAD.Foundation TechNotes and FAQs]]
